- Sep 3, 2011
- 478
Monarch is not going to share or even sell you the drawings of any parts, period; that's not how they roll.
Monarch classified the drawings for round-dial 10EE as "OBSOLETE/DISCARDED". They don't maintain them like they do their active drawings and can't find them very easily, if at all. I tried to get a set of round-dial assembly drawings, like they have for the square-dials and Terrie had almost no luck finding them. Many parts, like the cross-feed screw, wound up on the square-dial and they can still make them. Other parts, even things as simple as the felt wipers for the carriage, can be a problem.
All you will get for you money is a photocopy of this manual: http://bbssystem.com/viewtopic.php?t=1507
and a copy of wiring diagram. They send the same diagram, regardless of what your machine actually has.
The backlash in the cross-feed is adjustable by tilting the nut. If the backlash is the same in the middle as it is on the ends, your cross-feed nut may just need to be adjusted. If you Google "Adjusting 10EE Crossfeed Screw Backlash" you should find my article on adjusting it.
