Sorry for late reply.
Microscopic examination would help
I am waiting for the close-up pictures to be taken but was told not to expect miracles
As soon I get them, I will post them!
There were however some differences....
-most had light scratches that I assume are from normal circulation
-some had deeper marks, not sure the cause
-I believe there were at least three slightly different designs; mostly noticeable in the beaver tail
If you are interested in understanding the many types of errors found on modern coins, this web site is the most complete offering good explanation on the various errors you will find. It is possible that designs are different from year to year but highly collectible and sought after when it is within the same year!
http://www.error-ref.com/
A damaged die would be simple to replace.
Agree but it depends on the damage. Here is a brief overview on minting process.
Design is implemented on a Matrix. The Matrix is used the create the master punch (positive image). Some slight modifications can occur on the master punch. The master punch is then used to create several working dies (hubbing process). The working dies are polished and buffed before being used on the press to mint the coins. During the minting process, maintenance to the working die is done to prolong its life. Eventually the matrix, master punch, and working dies gets destroyed.
It was my impression the coin dies were hand engraved. My theory is that the die got damaged late in the production cycle and that a local repair was made to permit finishing the cycle prior to thr new year's coins. A repair would remove material from the die causing a raised area on the struck coin
This is most plausible cause of what happened.
Based on rough measurement estimates, the width and height for parallel lines seems to be on average about 4 mils .
My question:
Therefore, do you think the tools available in 1992 were able to do such a repair and if yes, can you provide me with some reference of what you think could have been used?
Thanks everyone.
