Help finding a replacement gear
The extend what dalee said. My dad had an expensive Zerox paper shredder ,$400 price range, that sheared the teeth off a cast brass gear (most likely sintered) . I called company and they sold no parts. So I made a steel gear to replace it. Few week latter the next gear in the drive broke. And you guessed it I went down the whole line. :banghead: Then the motor went out and I replaced that one of course with a higher tork one. and final the frame bent so I put gussets in it. After all this I was over I was over there one day and watched him drop a magazine in it. "jawdrop: I realized my mistake I never asked him how it got broke. :lmao:
OH well funny story,
Jeff
Re: Help finding a replacement gear update
Well, they brought me the broken gear tonight. It has (had) 55 teeth, 2.345 dia, .377 thick with a .750 bore. It meshes nicely with the change gears from my Micromark 7x14 lathe. Thus, I would guess its metric Mod1.
The person needing the gear showed me the webpage for a replacement set of 2 gears for the lift chair as a cost of over $90! Robbery! There has to be somewhere to get a suitable replacement for much less than that.
I’ve checked Boston Gear and Stock Drive Products and they don’t list anything close. Any ideas?
This is for a lift chair for a 83 year young Senior Citizen.
Chuck in E. TN
Thanks, EdK, the QTC gears is the best price so far. It would still have to be bored to fit the shaft, but I wouldn't have to make the entire gear.
Thanks to everyone that has posted a link. I check them all, but haven't found any but the above that could even be modified to work. Any more?
I forwarded that link to the folks to consider. If they get it, I will bore it to shaft size for them.
Chuck in E. TN
