help construction jib crane design for workshop
Oh, I see. I was wondering if you designed these and if so, how did you calculate the math and geometry to know the load rating?
[ Oh, capisco. Mi stavo chiedendo se avessi progettato questi e, in caso affermativo, come hai calcolato matematica e geometria per conoscere la valutazione del carico? ]
I have knowledge of traditional engineering and was wondering if you did the calculations yourself or, if you used a computer design tool.
[ Ho conoscenza dell'ingegneria tradizionale e mi chiedevo se hai fatto i calcoli da solo o, se hai usato uno strumento di progettazione per computer. ]
Ray
Titolo: Re: gru carroponti dispositivi di sollevamento
Gio Feb 01, 2018 4:57 pm
gru braccio a bandiera fatta in casa
une potence d atelier
http://www.metabricoleur.com/t3985p75-une-potence-d-atelier
http://www.metabricoleur.com/t5811-realisation-complete-d-une-grue-d-atelier
1521911846000.png1521911884341.png1521911919490.png1521911971032.png1521912012007.png1521912046922.png1521912093295.png1521912138624.png1521912188122.png1521912233790.pngcrane 1.jpg1521911846000.png1521911884341.png1521911919490.png1521911971032.png1521912012007.png1521911971032.png1521912012007.png1521912046922.png1521912093295.png1521912188122.png1521912138624.png1521912233790.pngcrane 1.jpg
I have to speak with a turner to make me build the hinges to tie the pillar to the swivel beam, I think I have to insert ball bearings or bushings bushings, what do you advise experts?
I made an A frame once and discovered real fast that solid hard rubber tires were a mistake. Be sure you use steel or nylon covered steel wheels. The solid rubber ones would flatten out with a load on it...lol made it difficult to roll :-(
gru 1.jpggru 5.jpggru 6.jpggru 7.jpggru 2.jpggru 3.jpgcrane 2.jpgcrane.jpgcrane 3.jpg
a locksmith friend of mine has realized this thing you think how to improve it which mistakes to correct in your notice thanks
