- Feb 13, 2018
- 179
As they say, your experience may vary. I've seen the tube and/or ends destroyed in the removal process you describe. Some may come out as easy as you say, but some will not and will be distorted; seen it happen more than once.All you have to do is clamp one end in a soft jaw, grab the other end with pliers wrapped in tape, as not to mar the finish and the end comes right out. The ends are not pressed in very hard at all, maybe 15-20 lbs of force.
jack vines
