Nice builds, welcome to the site. Little advise never think 12" lathe is to big. I wouldn't advise anything smaller unless your a clock builder or jeweraly dealer. Before the LATHES a year old I bet you wish you went even bigger. Read up on the LATHES you'll find small take small cuts and lack the strength to do some jobs like parting . A good place to learn is YouTube , Mr Pete , Abom, doubleboost @ funny guy ,, oxtool.
Welcome! I built the Gingery stuff you have plus a couple of other furnaces, the mill and dividing head. His recipe for foundry sand has worked well for me. Be sure to mix well dry so that each grain of sand is coated with clay. Moisture content is then just an experiment. You will learn to squeze a handful and see how it holds together and breaks.
Welcome from a fellow New Yorker. Not too far from the Ithaca area... Dansville, which is south of Rochester about 40 miles.
I need to finish my foundry. How do you lift the lid/cover on/off?
Or don't you use one?
The foundry I'm finishing assumes two people both able to do a controlled lift on a bar inserted in some hooks on the heavy lid.
Looking for ideas.
MN
Thanks for the advice re: swing size. I've also noticed that the smaller lathes don't have much travel in their compound, cross-slide, or tailstock quill, and I'm thinking that'd be pretty limiting.
I've been watching Mr. Pete and Abom for a while now. I can't understand a word doubleboost says . Another channel I like is Halligan142. His is the first machinist channel I ever found on YT.
Nice! I bet the mill was a big project! How long did it take you?
My greensand is pretty dry right now, so I'll find something to tumble it in, give it a good mix. Thanks for that tip!
So many upstate New Yorkers, and so many from the Rochester area! Nice to meet y'all.
Hi Daryl, There is a lid, I'll see if I can find another picture. I also made some lifting tongs so I can safely move my crucible. For pouring tongs (I think it's called a shank?) I use regular fireplace log pliers for now .. probably not the safest, I worry about squeezing the graphite crucible too tightly.
