Could you please help me this statement? I am contemplating on modifying the OEM stand/base on my old 1236 lathe.
Thanks.
My recommendation is about cutting and fabricating a frame of tubing [square, rectangular or round].
"Splay" the legs so upper plane is smaller than footprint. At least two pair, say right side and back, should also be braced diagonally. The box form of a
heavy desk should dampen fairly well too. It seems like one of those awfully big for a small machine, the back will collect chips or bad storage. A back-stop would fix that and make both sides useful. They are often called 'tanker desks'.
Finally, what ever form the lathe stand takes, provide leveling screws and
thin dampening like felt or hard rubber.
Took a look at local craigslist. Right now 15 "heavy steel desk" listings appear. One or two are right variety - rounded corners and means of assembly not readily apparent -. The others are sheet metal panels screwed to 3/4" square vertical tubing legs; the chief stiffening is via the pressed wood top, which ceases once a substantial load is placed. Also, places legs at the corners - the top will bend even easier.
Smaller 'tankers' have the legs outside the drawer sections, the bigger have short legs under the drawer sections that triangulate loads very well.
