Congratulations to Mr. Eric T. of the Netherlands!
Eric purchased the "Drawings Only" version of the Heavy Duty Knurling Tool Kit and did a fantastic job of his build.
Below are his words and photos.
Hi Doug,
Finished the knurling tool and quite happy with the end result.
Made entirely of offcuts I had in the shop. The only parts I had to buy were the spring and the knuling wheels.
Drilled and milled the upper and lower arms from a solid block of cold drawn mild steel.
The main body plate from two bits of hot rolled welded together and then milled to dimension.
For the pins I used the shanks of some old drills because I don't have any O1 tool steel.
The brass bits are made from the internals of some old pressure washer guns.
I need to get some shorter set screws for the wheel pins, because the ones I have are a bit too long.
I haven't decided yet if I'm going to cold blue the parts or spray them with Boeshield T-9.
I think the latter, because I do have that on the shelf.
I do have to do some more tests and get some experience with feeds and speeds, but the first results look very promising I think.
Thank You for making this available.
Cheers,
Eric
Congratulations to Eric T. of the Netherlands.
Get your heavy duty Knurling Kit here.
Heavy Duty Knurling Tool Complete Kit NOW SHIPPING!! Fantastic project for the lathe and mill (95% lathe work). Complete materials, hardware and drawings to create a valuable tool for your shop. Even the smallest of equipment can be used to produce this kit. This kit will provide several...
d-gray-drafting-and-design.myshopify.com
