- Jul 6, 2022
- 171
I've been trying to learn how to make a heavy cuts on a victor lathe (and it can handle the load).
The problem is I've not been able to produce good chips off the cut. I would run it at about 300 rpm or less, with a diameter removal of 4mm (2mm depth of cut), and at lighter feed rate I would get bird nest of strips coming off the stock, and that ends up being a problem. I tried to kick up the feed rate to get the chips to break but it ends up causing the tool post to move (resulting in broken inserts).
I had to reset the tool post, reset the compound at 0 degrees to give me the best rigidity and even then the chip doesn't look that good though it does break...
Is there any guide on how to properly take a heavy cut? I watch Abom's video and the feed rate he's making seems to be around B1-A5 setting on the feed rate dial (basically about 0.017" per rotation)
