- Dec 24, 2020
- 1,211
I'm just looking for a sanity check here. I bought a surface grinder a while back that needed just a few things done to it....new ball cages, restring the drive cable and new wheels. I took care of all that and started to teach myself how to be a bit of a grinder hand. The one thing I held off on was grinding the chuck because I understand that to be a bit of a challenge for someone new to grinding, especially so without a coolant setup. Still, I was getting more than reasonable results and no major issues.
I recently decided to make some parallels for my shaper vise when I noticed they weren't coming out as level as I would expect. I started with two pieces of cold rolled mystery steel that was approximately 1.25" x .875". I started with them laid flat to work on what will be the "sides" of the parallels since those surfaces aren't as critical as height. They were roughly centered in the middle of the table both X and Z directions. I marked the pieces so I knew the orientation on the table, and took the measurements in the pictures with them oriented the same way they were when mounted on the table.
I started with a fresh diamond dress of the wheel, and then took roughing passes that were around .002" deep with about .035" steps each pass. After I was sure I was making contact the whole length and width of the two pieces I dropped to a .001" pass, then to around .0003" with a smaller step of around .025" and would do several passes until it sparked out. It was probably one or two passes at .002", one or two at .001 and then a couple at around .0003". I put a fresh dress on the wheel, flipped the parts and repeated the process.
The wheel used is a new CGW 7 x 1/2" 46I.
As the picture shows, the two pieces are .0004" thin at the center suggesting the chuck is high in the center, but otherwise pretty consistent...at least within the range of my ability to measure carefully. If I measure additional points between the ends and the middle there is an obvious slope, so it's not just one high spot in the middle causing a problem.
I never removed the chuck to clean under it, and I have no idea how carefully it was torqued down to the table. Visually, the chuck looks pretty good (made in Taiwan, so I'm guessing 80s) with no major issues and I do run a stone over it before mounting the dresser and parts. If it was heavily worn I would expect it to be low in the middle causing parts to be thicker in the middle.
Since I was grinding dry I could feel the parts get a little warm, but nothing dramatic. Still, heat will make things move, so it has to be considered. Does this sound like it's time to grind the chuck or add coolant and see what happens first? Either way I'm putting together a system with a 5 gallon bucket, coolant and a Little Giant submersible pump anyway since the machine is set up with a coolant tray and a drain.
Thoughts?
Machine when I unloaded it:
Picture showing the measurements:
Thoughts?
