I've learned it can take a day. Your initial adjustments.... take a few minutes between each one and clean up the shop. Things settle. Then check it again the next day... because things settle, and it takes time for big heavy things to move/bend.
It depends which end is larger. If the headstock end is larger by .00015" that is unacceptable. If the tailstock end is then that is acceptable.
The acceptable range is 0-.0008" over 12".
