I have a HF powder coating unit. Actually works quite well. Powder coating is my preferred metal finish, if it's applicable (see below). Baking the finish is the "hard" part. Coated some new (i.e., clean) steel parts for my SB Lathe (made a taper attachment) and the finish is tough as nails!
Here are some hints from my experience:
1. There are several commercial powder coating manuals free on the net. Got one from a German source, but can find it again. Here's another one:
http://www.interpon.com/NR/rdonlyre...B4-C0635A91B22A/192/GuidetoPowderComplete.pdf
2. Material prep and suitability is a big issue, i.e., probably can't coat my SB lathe parts because they won't fit and I probably can never get them clean enough to stop oozing oil out of the crevices. Also worry about inadvertent "heat treating" the CI in the wrong way. Might warp my lathe bed.
3. I got my non-HF powder from Caswell's (
http://www.caswellplating.com/powder/). As mentioned, the epoxy powder really stands up to abuse (but not UV outdoors).
4. There are at least four different chemistries of powders (see the above manual), with different properties. Know what you're getting and use it appropriately.
5. Baking is the issue for me, for several reasons. First is size. I only have a toaster oven so am limited to small objects. Keep thinking about super-sizing it
There's plenty of heating capacity in it.
6. But temperature control and timing are important, too. I use both an IR (laser pointer) gun and a thermocouple gauge. The toaster oven thermostat is all over the place, 50-100ºF swing. Totally unacceptable. I keep thinking about replacing the thermostat with a cheap Type-K thermocouple digital power controller ($30 new from China on eBay), but haven't done so yet. May not need to -- I notice that the new crop of toaster ovens at Walmart, etc., have digital controls, which I suspect will be much tighter regulation. We'll see.
7. Coupled with the temperature swings is the issue of preheating large masses. One of my parts was made out of 1/2" thick steel plate. Stuck it in the oven, covered with powder, but cold. The powder got too hot in some places and overcooked before getting hot enough to flow out elsewhere. Need to sort out whether preheating or better temp control would solve the issue.
Having said all that, I really like powder coating parts when I can. The results are just so great, both in looks and durability.
HTH,
Mike
