- Oct 7, 2020
- 2,356
Maybe it's not a problem but the keyway on my lathe is 5 mm the ones in the listing are 6 mm.
I'm looking at the Clough42 ELS for my PM 1236 lathe.
Question about operation: Do the up/down buttons for feed rate require repeated pressing, or can you keep them pressed to operate continuously?
Either way, I'm not a fan of fiddling with the tiny buttons; does anyone think it would be desirable to have potentiometer control instead?
If so, thoughts on how feasible such a modification might be?
I'm thinking that for turning it would be nicer for adjusting feed rate to get the chips to break.
Ah, right, it would need to be a rotary encoder.
Do you think having a knob for feedrate vs. buttons would be a worthwhile improvement?
95+% of the time I'm turning and not threading.
You know that's completely silly, right? So your start turning and you want to just fly thru the feed rates until you stall your lathe or destroy your part?
I would suggest using it stock first and deciding if you want to change things later. It's easy to get feature creep before actually using one.
