I have problems with my hands makes it difficult to hold and control the dials on my lathe , I looks a James els but as it was only on the Z axis I thought I wouldn’t be much better off, so in the end I decided to buy the full kit from Rocketronics in Germany and I love it.
It is amazing how much it can do although it wasn’t cheap but it means all I have to do is add a few parameters into the els 4 controller and it does the rest , I can still turn the steppers off if I need to do something manually, it will turn, face cut internal & external tapers, thread both metric & imperial ( convert to metric ) including taper threading, multi thread , grove, bore, and so much more.
I have a Myford ML10 lathe and fitted everything without having to drill or thread any extra holes , a closed loop stepper to leadscrew and normal stepper to crosslide , enchoder, pulley’s and belts all fitted in place of the change wheels and the cover still fits.
I have done a short video of it working, not the best video but it shows how it works, the first part I hadn’t measured the backlash correctly so the backlash settings were wrong but once I sorted that it did a good job.
Dell
