I found out even more about the Vexta motor. Looks like the 5-phase, "delta" wound stepper is their bailywick. They have their own driver chipset and proprietary drivers...
I tend to think Gecko is just gonna say "Huh?"
Do you have an application for these? CNC usage? I bet Vexta can get you the motor's specs if you call them. If you can't get the datasheet, now that I know what's inside the motor, I can show you how to find out with a power supply (maybe a car battery?), a multimeter and an in-lbs torque wrench (beam type, if possible). If you have an oscilloscope and a cordless drill, we can really get some good info about this motor by backdriving it and looking at the back EMF (generator voltage)!
I also have some ideas on how you can identify the leads to find out which is phase A,B,C,D and E so you can wire it right to whatever controller you can get.
If you run out of luck finding an affordable driver for these, and really want to use them, let me know (I have a thought or two).
John
John, it does look like Oriental motors has dedicated themselves to the 5 phase stepper. The major sales pitch is less vibration and higher resolution, which is of nominal value to me.
I have 5 steppers from the garage sale. One is small and of little use to me, it's like others I've collected from old machines. The other three were in boxes labeled like the one I have been discussing and I assumed they were the same. BUT, I just went down to the basement to see if there was any info with them. To my great surprise, two other motors are PH-299 E4.0 which are 4 amp 2 phase steppers, the remaining stepper is also 2 phase, but smaller.
Now I have a quandary! I'd love to make the 5 phase motor work, but it's an orphan, and I have 3 steppers that are "normal". OTOH, the small step angle of the 5 phase unit really appeals to me for a rotary table, such as Steve Ward designed on CNC zone - although I first saw that unit as Malcolm Parker-Lisbergs version mentioned in a yahoo mini-mill forum.
I do want to add John Dammeyer's E-leadScrew to my 12" craftsman lathe, but that only uses 2 steppers. I also have a drill mill that occasionally entices me with whispers of secret cnc codes (hey, Halloween is coming, I'm trying to get in the mood).
I see a 5 phase driver on ebay for $29, but it's a .75 amp "seller refurbished" item. I wonder if I could have the output feed ?mosfets? ?some circuit? to get a higher current? Not sure enough of the output waveform/signal/electronics to assume anything about that! Or, I can buy a used driver for $199 and up... not really in my budget.
I found a paper insert in English that shows the wiring for PK PX type, 5 phase motors. The color code matches the winding pairs I have even though it's a PH type motor. If the phases correspond, then the connections are;
A - blue > red
B - white > yellow
C - brown > purple
D - black > gray
E - orange > green in order around the motor
Unfortunately, there aren't any power/torque/electrical specs with the insert.
I have a spare car battery, 2 amp power supply, multimeters, maybe access to an inch pounds torque wrench (or a lever arm and weights?), a friends o-scope, multiple cordless drills and 4 friends that will enjoy helping me play with this toy! I'm ready (or as another friend would say, "let's get you over to the deep end of the pool"). It would be great fun to experiment with it if you have the inclination to enlighten me?
As I posted in another reply, I found late last night that a member on CNC forum (another place I haven't been in a while) was building and testing a 5 phase driver last year. I need to find the rest of his posts and see if he was successful, and if the parts are still available, and if a board design exists, and if it requires a programmed pic, and if, if, if.. So, if you want to share your ideas, I'd love to hear them. If nothing else, you're stimulating an old mans brain, which can only help me live longer! LOL
Thanks very much,
Rex
