Wow Oh Wow !!!
Can only admire U Guys ingenuity
Still trying to pluck up enough courage to start refurb work my Chipmaster Lathe
Needs just as much work, if not more
Except U Guys have the know-how
Keep the pics roling
aRM
The new belts helped a lot but needed to align the motor and variable speed drive to really smooth it out. You'd wonder how they would ever have gotten shifted. The new belts aren't Good Year like the originals, these are made in Mexico and don't run perfectly true.
Anyway, she turned its first part. An arbour to hold the gear cutter to make the gear to repair itself. Sure leaves a nice finish and no runout on the collet.
Its unnervingly quiet after running gear head lathes. Was concerned that my cut gear might not be perfectly formed, causing a pattern in the turned surface but all seams to be good.
Im getting about 1/2 thou taper in 8 inches guess the tailstock needs tweaking. Overall think its going to be a good machine.
Thanks for watching
Greg
That's a great restore. The Hardinge is one of my all time dream lathes. I think it's hard to beat the curves of a HLV, a Rivett 1020s or a humble Colchester Chipmaster.
