F
f350ca
Forum Guest
Register Today
Picked up an older HLV on auction that apparently has been sitting for Years in storage at a government research center. Valleyboy101 met me last week and we looked it over before bidding, decided it looked pretty good.
Unloading it at home
It has a few issues, it sat so long the belts had deformed around the pulleys, causing them to thump and shake the machine. The grease in the threading gears had turned to hard varnish, had to tear the end of the headstock pretty much totally apart to get them out and clean. Suspect the carriage got bumped in the warehouse and damaged the pinion which mates to the rack for carriage travel, but the rack is fine?.
When I had it far enough apart to address these things figured we may as well continue and dismantle the rest and paint.
There's a lot of parts in a lathe.
