E
ecdez
Forum Guest
Register Today
Welp, I had my first crack at making a forming tool from O-1 tool steel. It's 1/4" thick, 1 1/2" wide and about 2 1/4" long. I'm using a dental oven that get's up to 2000º so heat's not a problem. Here's what I did.
First try.
Heat steel to 1490 (or so I thought)
Quench in oil
Once it's cool enough to handle it goes straight into the oven at 300º for 2 hours
Pull it out and run a file over it,.... scratches like it's mild steel.
Do a little more research for the second try.
Second try.
Heat steel to 1490 (I think)
Test with a magnet and it's not at all attracted to the magnet (according to the internet this is an indication it's ready)
Quench in oil
Check with file and it slides right off, yea! (not until later that I remember I used the flat end of the file and not a corner)
Once it's cool enough to handle it goes straight into the over at 300º for 2 hours
Pull it out and run a file over it (corner of the file),.... I can tell it's harder, but the file still digs in
I got the temperatures right off the sleeve the steel came in from Travers.
I'm using clean motor oil (last resort I know, but it's what I have on hand)
I did use the same piece for the second try which might have been a bad idea but I figured if it didn't work the first time then it's not hardened and can be tried again.
Anyway, I was hoping someone here might have some experience and can point out my obvious flaw in my process.
Thanks in advance!
First try.
Quench in oil
Second try.
Quench in oil
Thanks in advance!
