Question for you construction/framers out there, or if you have hands on experience.
Is it reasonable to spread out the 1,320# load over say, 4 rafters to support the hoist and the load?
I am thinking of a roller strut design with u-bolts wrapped around the rafters to support this hoist https://www.ebay.com/itm/1320Lbs-Mi...G0:sc:FedExHomeDelivery!95926!US!-1:rk:7:pf:0
Have you done it?
Did you lift a 1,000lb load safely?
Is this a stupid idea?
What about 500lbs?
Thank you.
It sure looks like a great way to lift heavy objects on to the lathe (12" chuck) or welding table or.......
I did mount an electric hoist to the rafters, not the joists. This was in an opening in the ceiling of my shop next to the pull down stairs. The hoist is rated for 440 lbs or 880 lbs using a snatch block . I bolted 4 steel brackets across 4 rafters and a 1-1/2" steel pipe bolted to the brackets. The most weight I have lifted so far was about 325 lbs. In your case I believe you mean joists. I lifted a 900 lb mill-drill with a come-a-long using the ceiling joists for support. I installed two 4x4's , one on top of another to make a 4 x 8 . This spanned 3 joists. Then bored a hole thru and added a 5/8" length of acme threaded rod with plate washers. The come-a-long hooked up to the rod. I used acme thread because I had it on hand.
This worked out fine but you need to know if your joists can take the weight. My joists are 10" engineered ones on 2-0' centers.
mike
