- Jan 2, 2019
- 6,748
Or maybe one of those anti-fatigue mats would be good.Maybe I can cut up a pool noodle to pad the handles.
John
A long time ago I was a new millwright apprentice and didn't know how to change the bit in the Hilti.@CJ5Dave
Push the chuck sleeve (ribbed bit) backwards to release the grip whilst you fit/remove the bits.
Grifter, I just reread your post and saw the info about adding grease. My pin scanner. Anything else work? Maybe snap ring pliers?
Yes, it has a hammer only function and that’s all I want at the moment. Thanks. Need to chisel some concrete.
even wood wedges will do that.The label says rotary hammer? I think on the SDS there is a a lever for the rotary action vs hammer only? (My old Hilti is the old spline drive format where the rotary action depends on the configuration of the spline on the bit.)
If you have any decent sized piece of concrete that you need to break up I HIGHLY recommend renting or borrowing a full sized jack hammer.
I went at a 4' x 4' concrete pad with my old Hilti rotary hammer and made very little progress on it at all. A friend brought over his HF 120V jack hammer and it finished the job quite quickly.
P.S. There is also expanding hydraulic cement. You drill holes in the slab. Fill the holes with the expanding hydraulic cement. As the cement cures it expands and forces the concrete to crack apart.
