Had enough leaking oil!
Thanks Mike, I’ll get these on order. Would you know if an older machine like mine will take the newer top seal?
CH
it will work fine, They didn't change the mill at all, just the seals they use.
I think if you look on the PM web site you will find the same model number. They probably all come from the same place in China. If you go there and look near the bottom under manuals you will find in the manual an explosion drawing with parts and part numbers. There will also be a corresponding parts list for the drawing.
Dave
By the way, my PM940M CNC looks similar, but probably bigger, and it drips oil as well. Not so bad yet, but sometimes I would rather not have it drip on my work!
Right, been there done that! But if you look at the parts list part numbers past “119-152 are all in a separate manual”. Any way got what I need to order, heading in to Colorado Springs to Whistler Bearing, and see if they have or can get the seals, and new bearings.
CH
Let us know what you find out. I may want to change mine one of these days.
