H&R Fore end spacer project
SEK_22Hornet
I'm a newbie to machining with no training, trying to learn how to do a few machining operations. I have several projects in mind, mostly gun related, so Friday I decided it was time to get down to business. As I posted earlier, one of these is making some barrels for my rifles, but I think that will wait a little while. I really want brass fore end spacers on my Buffalo Classic and Carbine, so I decided I'd see what I could do. I have a little aluminum scrap that is the right size, so I decided to see if I could actually get something that would work made before spending $50 for brass stock. Here is where I'm at right now - I'm actually pretty pleased with my progress. Mainly need to cut it off and machine it to length and drill and countersink the holes. That probably won't happen until I get a nice warm day again (my shop is unheated). Here are a few pics - comments are welcome (and encouraged). I realize I should have taken some photos while in the process, but didn't think about it. I'll try to remember when I get back into the shop. I'll probably make a second one out of aluminum before moving on to brass just to make sure I'm comfortable with my process.
That's good looking work. The bulk of my machining is in gunsmithing and I actually have to make one of these as well. Looks like you have the process down very well. I would like to see pics of the set-ups you used to cut the radii.
Again, nice work.
Thanks - I'll try to get a shot of the set up - I used a small 4" rotary table on my G0704 Grizzly mill with a small milling vice mounted to it.
It isn't a perfect fit. but it is within a few thousandths. I used a 1-1/8" milling cutter to cut both the barrel and pivot radii. The outside radius was cut using a rotary table. Here are a couple photos - not while I was cutting the part but the two mills were still set up so I just clamped the part in a took a quick shot.
Thanks for the link. That's a neat kit. I wonder if the vise can be purchased separately. I thought the outside radius was done on a rotary. Inside I thought you may have used a boring bar or fly cutter on the mill. The fit looks better than the factory.
I hope to get back into the shop this weekend and finish the prototype, maybe even get started on some fixtures. I want to make at least 3 of these for myself and I suspect I may be able to sell some if I make a few extras. I found some brass cut-offs on ebay so I have some brass coming to get started once I get the process and fixtures down.
Edit - I made a stop at the local scrapper after work and came away with a nice chunk of brass bar stock that should work nicely - 3/4" x 1-1/2" x 11-1/2" long, 4 pounds @$3 / pound.
