- Jan 3, 2013
- 192
I recently ran across the text below, and thought it might be of some interest to this forum (this is from "The Malay Archipeligo by Alfred Russell Wallace, 1886) - it describes gun making in the 1860s in Indonesia:
"At Mataram we called at the house of Gusti Gadioca, one of the princes of Lombock, who was a friend of Mr. Carter's, and who had promised to show me the guns made by native workmen. Two guns were exhibited, one six, the other seven feet long, and of a proportionably large bore. The barrels were twisted and well finished, though not so finely worked as ours. The stock was well made, and extended to the end of the barrel. Silver and gold ornament was inlaid over most of the surface, but the locks were taken from English muskets. The gusti assured me, however, that the Rajah had a man who made locks and also rifle barrels. The workshop where these guns are made and the tools used were next shown us, and were very remarkable. An open shed with a couple of small mud forges were the chief objects visible. The bellows consisted of two bamboo cylinders, with pistons worked by hand. They move very easily, having a loose stuffing of feathers thickly set round the piston so as to act as a valve, and produce a regular blast. Both cylinders communicate with the same nozzle, one piston rising while the other falls. An oblong piece of iron on the ground was the anvil, and a small vise was fixed on the projecting root of a tree outside. These, with a few files and hammers, were literally the only tools with which an old man makes these fine guns, finishing them himself from the rough iron and wood. I was anxious to know how they bored these long barrels, which seemed perfectly true, and are said to shoot admirably; and, on asking the gusti, received the enigmatical answer: "We use a basket full of stones." Being utterly unable to imagine what he could mean, I asked if I could see how they did it, and one of the dozen little boys around us was sent to fetch the basket. He soon returned with this most extraordinary boring-machine, the mode of using which the gusti then explained to me. It was simply a strong bamboo basket, through the bottom of which was stuck upright a pole about three feet long, kept in its place by a few sticks tied across the top with rattans. The bottom of the pole has an iron ring, and a hole in which four-cornered borers of hardened iron can be fitted. The barrel to be bored is buried upright in the ground, the borer is inserted into it, the top of the stick or vertical shaft is held by a cross-piece of bamboo with a hole in it, and the basket is filled with stones to get the required weight. Two boys turn the bamboo round. The barrels are made in pieces of about eighteen inches long, which are first bored small, and then welded together upon a straight iron rod. The whole barrel is then worked with borers of gradually increasing size, and in three days the boring is finished. The whole matter was explained in such a straightforward manner that I have no doubt the process described to me was that actually used; although, when examining one of the handsome, wellfinished, and serviceable guns, it was very hard to realize the fact that they had been made from first to last with tools hardly sufficient for an English blacksmith to make a horseshoe." (See attached an illustration from the book.)
When I'm working on a project and things are not going right, and I feel the urge to blame the problem on inadequate tools, I like to reflect on passages like the above.
