- Jun 12, 2018
- 724
I made a part out of 1018 cold rolled yesterday. I was using a 1/4" HSS endmill to cut 2 slots. First slot went without any issues. I was doing around .030 each pass until I hit the total DoC of .170 and the length of the cut was at .600.
The second cut I decided to do all .170 in one pass. When I started feeding, the workpiece became "gummy" and I was hesitating to feed since it became harder to feed in, fearing of breaking my endmill.
I then decided to do much smaller DoC at around .010 per pass and even then, it was rather hard to feed as it was pushing out gummy metal to the side of the slot that I had to file later on.
I forgot to use cutting fluid on the first slot but it cut fine. I only remembered to put in cutting fluid on the second slot when I noticed the gumminess of the part.
Spindle RPM was around 1200 and I was feeding slowly.
