- Apr 29, 2019
- 2,250
I was looking at Speedy Metals, I was surprised to see the the cheapest, or should I say "least expensive" Ø3.00 x 48 steel bar was 12L14. It was even significantly less than the 1018 and a much better material to work with. But still not cheap at $167.
Midwest Steel supply has the Ø3.00 x 48 12L14 for $139.
McMaster and OnLineMetals are both stupid expensive.
A bar this size is about 95 lbs so shipping may be an i$$ue, getting two 24" bars will be about $1 more for the material but can be shipped ground in 2 packages. at $1 per cut it might not be bad to order it in 6" bars. But shipping for near 100 lbs will still not be cheap.
Have you checked with some local places to save the shipping cost? This part is not fussy about alloy so check to see if they have any drops of whatever kind of steel?
