- Aug 13, 2020
- 1,342
Thanks to my wife, Lena, I finally got all the bases squared up today. Floor is still covered in a layer of tiny knives. It took quite a lot of manipulating to get the setup right and rigid enough that I can lay a square on it and get even light through all the way across.
Unfortunately, I am not going to be able to hold the dimension of .720" on the wall thickness. By the time I get it cleaned up and then square, I'm down to less than .700" on several of the pieces, and I still have the inside face to clean up. I'll most definitely keep the dimension between the inside faces of the two sides, and the Auxiliary base doesn't need to be cleaned up at all. I think the only change this is going to necessitate is that the shoulder on the trunnion on the main base side be only .600" thick. Maybe .575" for good measure. Not sure how thin we can make it and still have room for the register holes.
Other than that, the pace should be picking up now. I've got the tools made, and spent the last week getting the mill dial in much better. Used the grinding wheel to the table flatter, and trammed it better. Getting the outside faces square is going to be the hardest part of the whole process, I think. I have something to register on for all the other cuts.
