Have you considered what it would take to move a surface grinder into your basement?
It is possible to start a business on the cheap. Do you have a product that you think you can make & sell or are you planning on being a job shop?
If it is producing a product, how are you going to market it? What prevents the next guy from copying it and making it cheaper?
If it is to be a job shop what skills do you bring that would make someone want to use use you rather than all the other job shops that have established themselves as providing good service doing repairs or perhaps short runs? You must have a product that requires high precision parts or you wouldn't be talking about surface grinding to those specs. In addition to the machines you've listed you must also have a means of powering them with 3 phase. Rare in US homes so you are looking at a converter? Electrical, DIY 3 phase or hiring an electrician?
In developing my own business I sometimes bought used equipment, got burned a couple of times and learned to buy only things that had excellent factory support. It costs several thousand $ to have a tech fly in to service complex machines. I spent $101,000 for a used saw to cut particle board, by the time it was installed, hooked to power, air and the server + software I had another $15K into it. The main job I bought it for dried up as the company suddenly quit expanding. Schelling makes great saws but they need to be fed lots of work to justify their cost.
Plan ahead! But it is still a risky bet. BTW I sometimes had to borrow $. They always wanted everything I owned as collateral, house, car, kids....
Thanks for the reply.
I first put thought on how to move the heavy ton machines into the basement before considering which particular machines to obtain.
I have concluded with certainty that it can be done without much great effort using this method, my basement is similar in nature:
Good to hear that it is possible to start a business on the cheap, I have bought many used high quality items off of eBay and craigslist, all of them are good experience and was never a 100% potato/loss. Just last week I bought a used Summit washing machine from craigslist for $150 which originally costs $1,500, the machine looks brand new and works great as expected but does acts weird when drying and something I can fix when I have time.
I have about hundreds of items to produce and sell, everything are mostly for niche businesses, few companies are in the business to produce them here in USA.
One of the many example in my list are in the research/labs sector, such as Klein Flansch or known as KF Flange, not much competition in this niche and there are great demand for it here.
Expensive to buy these parts, depending where you get them from. If needed I can break even by selling them cheaply.
Also I want to make KF Flanges in many different forms, not just the ordinary ones, create a catalog, make parts that are rare such as glass-to-metal KF Flanges which are tricky to find, so that it can now be easily bought off of Amazon/eBay for customers.
These parts I plan to make can only be bought by specialized companies who never directly sells them and requires a MOQ (Minimum Order Quantity).
95% of the work I will be doing are making and selling on platforms such as in: Shopify + Amazon + eBay + Etsy.
I have taken numerous marketing courses and did business in all of those platforms, give me a niche product and I can sell it.
5% Job shop work, happens when customers asks me to make a product I make and sell, to suit their exact needs.
From experience, the best secret to any business is consistency of doing business.
Also KF Flange is just one small category example of the hundred of niche products I want to make.
Surface grinders comes into play for example making the best and precise fixtures plates used in labs which uses them commonly.
I'll buy a 3-Phase VFD converter which can take single phase, I sometimes do electrical work, I'll call in an electrician if I'm working anything over 220 volts from the main panel, don't want arc flashing risking on me.
Yikes, $116K for a saw... you make cabinets?
I consider a good hobby size machine to be in the 12x36 range. Accuracy will mainly come from the operator so anything that's mechanically sound should work. You'll want a QCGB so probably not a very old machine, I have a 1980's Taiwan built 12x36 that I bought used for $800 but I don't know what's available where you are. Grizzly and Precision Matthews offer new machines that will also fit the bill at reasonable prices.
As stated in your other thread, if you can find a well cared for machine from a hobbyist or one man shop with included tooling that will be your best value. Post whatever you find on this forum and you'll get an honest opinion from lots of folks here. Pictures help a lot....
Since it sounds like you're just starting, and don't yet have a solid list of projects I'm pretty confident saying starting out with a lathe and learning how to grind HSS bits will serve you well. It'll likely take a little while before you can hit the dimensions you want and be happy with the surface finish. Once you get that down, going to any other machine will be easier.
John
I will keep this noted, look for at least a 12 x 25 lathe.
As for QCGB, I aim to convert the lathe to CNC.
Used Taiwan lathe for $800? Lucky you.
Thank You, I will post links and get feedback, will provide many pictures.
I agree, starting out with a lathe first is the way to begin machining.
