Thanks for that.
I only have 2 valves that are out of spec, yes. I don't have any spare valves (maybe one or two) I have a bunch of bent ones from a timing belt job gone wrong though.
I should have let you all know that I have a spare set of 16 buckets to play with. They are all just larger than the set in use unfortunately.
Would you still take an alternate route then? I didn't see where he was shaving the inner wall of the shim and I don't see that as being a problem for me if I were to go with the dremel setup. I have plenty of room to avoid making that mistake.
If I was to go the grinding the valve stems route, would you mind elaborating on your technique using the bench grinder. Sounds like you just eyeballed it. Is that ok? How did you keep it straight?
Also, with the file, how do I know that I am straight on that part as well.
What is an SG?
What is an SG?
