So, I want to make bits. I have a harbor freight bench grinder. Not a great tool to be sure, but can it be made usable?
I've seen the threads talking about modifications to a belt sander. That's another option. Any suggestions on what to look for?
I use a Black and Decker BT3500 6" bench grinder with coarse and fine stones, which is about as cheap as they come. I have used it for grinding bits mostly 5/16 and smaller for several years and it does a decent job. I first ground bits holding them in my hand against the rests which I adjusted for the desired angles. Then I purchased a small cheap Chinese quick change tool holder for 10.00 on Ebay to put the bits into for grinding. Now I am seeing these for 5 bucks. Later I found a tool bit grinding holder for 25.00 on ebay which can hold the bits at different angles on the grinder rest for shaping the bits. There are diagrams on the internet which show how bits are ground. You may be already beyond all this and way ahead of me but I thought it might help someone. I am strictly amateur and this is my limit LOL. Wayne.So, I want to make bits. I have a harbor freight bench grinder. Not a great tool to be sure, but can it be made usable?
