Wheel hub flanges - done!
This photo shows the two wheel hubs, now completed. The pieces are sitting on their corresponding page from the French Army document that was primary source for my CAD work for these components. I tried to come up with a good machining sequence on these parts, but I should have left more material on the ends for holding in the chucks. The tapered D-bit reamers featured in the prior posting worked well, as the inner hub mates nicely to the axle taper, and the outer flange onto the inner flange taper.
Next up: Maybe I can find a few more straight-forward piece to design and build. So far, the axle and hubs have been challenging, maybe I can do a few simpler pieces while I design the wooden pieces for the wheels. (each hub mounts 14 spokes that connect into 7 wooden "fellows".) Then there are numerous small metal brackets and fasteners that tie the spokes and fellows together and a steel "tire"
around the rim.
Greg
around the rim.
Greg
