OK sounds good, and you have the bearing knives now as well, so that is a good start. I like the OTC Bearing splitters as they use a single pressure screw, but I have a many of the style you picked up and they work well.
Now you need to get or make some press sleeves. I discussed them a depth in this thread.
http://www.hobby-machinist.com/showthread.php/19291-anyone-have-a-large-arbor-press?highlight=press+sleeves
Walter
Well l used one of the 50 mm (0D) bearings to seat the OD of the new bearing.it had to go into the housing about a eighth of an inch.
Worked well in that case.
Cleaned up a old 3/4” drive socket on the lathe and bored it to fit the press pinion shaft. Held in place by a pin through the socket and shaft.
A couple of feet away, is a 30 ton hydraulic press...the arbor press is always the first choice if the part will fit and not too heavy of a press.
