- Jul 31, 2020
- 765
All of this scary talk of controllers is fun, but I did notice the spindle for the tailstock appears to be missing. Is it set to the side somewhere, or did it arrive that way? The same is true of the feed screw shaft and end bearings. There seems something off with the half-nut lever as well.
If you are strongly driven to replace your motor, skip the whole PWM/DC motor game, and go with a Brushless Controller and motor. The new Brushless controllers are super fault tolerant and largely self protecting. Something similar to what the LMS 5100 or 7350 currently enjoy. If you find the bed on your lathe too short, LMS also sells a 16 inch bed, which should allow you to bolt all the other parts to it.
