- Dec 20, 2012
- 9,408
The graver is sharpened so there is a diamond shape with a high point as you described, but in use the sides are used to cut, not just the point. The same applies to the round graver - the whole tip cuts, and you'll be cutting both toward and away from the chuck. Don't worry - the tool will cut and it will rough and finish equally well. The round graver will take off shavings that lift into the air with a breath - you'll like these tools.
