One other thing to consider with glass is its creep factor. An example of this is the distortion one usually sees in old (80+ years) window panes. Old glass was made using the float method, so it was flat and clear, without distortion. But, as glass ages, it sags under it's own weight. And this is happening with the glass setting in its strongest orientation, edgewise up (which is why glass is always stored and transported standing up). You would be using it in its weakest orientation, laying flat, so the sag would happen much, much faster. So, if it was flat enough for your purpose when you bought it, you have no reason to expect it to stay that way for any length of time.
