- Mar 27, 2017
- 213
When I bought the saw it seemed to run just fine, however when cutting a block of steel it made a snapping and popping noise that bothered me and would become worse as the cut became heavy.
I decided to investigate the noise and discovered the small drive gear was missing some teeth. Further investigation and disassembly led to discovery of the cracked center boss on the driven gear and band wheel.
The pics show where the boss is cracked.
Had I known the parts were not available I may have not bought the saw. However the saw is one of the best built I have seen on the market. Not withstanding the fact I used this very unit many years ago and appreciated its abilities back then in the late 60’s.
So, I’m faced with replacing the gear or making a new one !
I like the way you fab’d your new one and hope I can do the same in the future.
If you’re willing to share your master cam file, that would be much appreciated !
