I thought about the load on those joists. Joists are designed in residential use to conform to a requirement for 40 pounds/square foot. If the room above is basically empty with no heavy floor finishes, that arrangement was spreading the load across maybe four joists, and those joists would be carrying 25 or 30 kips of live and dead load in residential use. Code loading for a single 2x12 is something like 180 pounds per foot up to 12 feet, and that's for permanent loads. More is allowed for short term loads (short-term being defined as, say, snow). The key is to spread the load. And looking at deflection, a single 10-foot 2x12 reaches design sag at 7000 pounds of loading, according to one analysis I saw. Wood is pretty strong if we can provide enough depth of section.
I want to install a chain hoist, or even a beam for a trolley hoist. Even throwing a chain over a single 2x12 bottom chord of one of my roof trusses would likely have raise my South Bend, had I been willing to trust a one-ton hoist. But hanging a beam from, say, six trusses would easily support a 2-ton hoist kept in maybe the center two thirds.
Rick "wood is strong but it creeps under high loads over time" Denney
