- Jan 22, 2011
- 8,016
In no case should you be taking a cut without taking out the backlash from whatever you move to set the cut, whether it is the compound, as in threading (for some folks) or the cross slide. It just isn't done
Not really the best approach. Shouldn't cut with forces pulling the part away from the chuck or bottom of soft jaws unless you have to. Use M04 instead of M03, and left hand tooling. And unless you have a sufficient width thread relief to start at the bottom, there can be sync errors with the spindle encoder trying to get everything up to speed. But, ya gotta get by with what you got sometimes.
I've pulled parts out of chucks on manual machines cutting -Z- plus. I try to avoid it.
Well explained Tony, personally I only use the compound when threading very course leads on multiple parts in a manual lathe, 6 TPI or less, I set the compound at around 45 Deg. or so as this clears the handles nicely. Touch off the tool with the cross slide and zero the X dial or DRO then set the compound dial to 0, then dial in the cut with the compound, retract the cross slide and return to the start. Return the cross slide to 0 and advance the compound for the next pass without having had to move it back, repeat as needed.In no case should you be taking a cut without taking out the backlash from whatever you move to set the cut, whether it is the compound, as in threading (for some folks) or the cross slide. It just isn't done
On that BP CNC lathe, would that be one of those ProtoTrak types where you can actually "teach" the machine by running a part manually and have the machine generate the code from how you ran it? I have always wondered how good those were. never had a chance to run one or be in a shop with one.
I know exactly the type of operator you are talking about. What they are really good at is "shrugging". I dunno what happened!!!
