- Sep 5, 2013
- 3,788
OP should also be aware that switching to a quick change style may also result in limited rotation of the toolpost on the compound. It has to with the peculiarities of the compound casting on both the Atlas 618 and also the Craftsman version of the same machine. The machined flats where the toolpost sits are actually lower by about an eighth of an inch or so than the rest of the compound casting, so you can’t rotate full 360 degrees without banging one of the square toolpost corners into that 1/8” ledge.
There are workarounds — raising the toolpost on a shim (essentially a large washer) so it clears the rest of the casting; milling/grinding/or filing two of the four corners off the bottom of the toolpost so it clears the ledge; or the most drastic of all, milling the top of the rest of the compound to be flush with the flats. It’s not a situation that renders the toolpost useless without a modification, it’s just in some positions those corners are going to get in the way and not allow for an ideal angle to the work. Threading with the standard 30 degrees on the compound may be one of them, I can’t remember right now, but there were enough times that it annoyed me enough to knock the corners off the toolpost and be done with it.
Just something to think about if the compound is of this style.
