- Mar 10, 2013
- 1,416
right on GG---my compressor is a 60 gallon tank 5 or 6hp and I add on extra storage tanks using quick connects when I need a lot of quiet air--the storage tanks can be outside under a cover so they don't take up shop space---the large propane tanks work good for extra storage---just put good ball valves on tanks to seal them off when not using and check your system for any leaks--they will waste a lot of air---I have about ten compressors in different sizes--and my quietest one is a 4 cyl compressor off an refrigeration unit---it doesn't pump up as fast to 120psi but it runs so quiet you can hardly hear it----I haven't got 220 wiring to my new shop yet, and when I do then I will start selling or trading my smaller compressors.----three compressors should be enough,----just remember you can get by now with a smaller compressor as long as you have an 80 or bigger storage tank and others to connect on.--I would look for an older large air compressor for sale---lots of people think the smaller newer compressors are better--so you may pick up a large one cheap----Dave
