- Nov 15, 2016
- 943
Actually the average modern vehicle operates at roughly 115 degrees Celsius due to the radiator pressure cap. The hotter you can run the better. You can get thermostats with an opening temperature of 97 degrees Celsius.There is one thing you are forgetting, this is a modern car, it is computer controlled and its ECU wants the engine at 90 degrees celsius to run correctly, the thermostat only opens when the temperature is more than 90 degrees, often when moving the radiator is stone cold, i've had check engine lights on other vehicles because engine temp too low.
Man I hate modern engines with all the bolted on emissions gear etc. May not be viable in your case but in a garage the easiest way to work on a FWD vehicle for major work is to drop the entire front subframe and lift the body off. It can be done with jackstands and an overhead hoist even in a small garage. Disconnect fuel and the wiring harness plus steering.
This leaves the engine sitting on the subframe which can be wheeled around with a bit of support from a skate. So much easier than any other method. Even AWD can be done like this.
Basically this is the reverse of how the vehicle was put together in the factory.
IF,(and it is a big if),you decide on another rebuild I suggest you give it a go.
