- Dec 3, 2013
- 1,849
as someone who just converted a hobby mill from dovetails to linear rails I have (biased) opinions on this, haha.
Linear rails have the advantage of not needing to be adjusted. Dovetails inherently have a small amount of slop to keep them from binding and to provide a place for the lubrication film. And as we all know, where there is clearance there is adjustment that needs to be made to maintain that clearance as things wear. This also means if things are too tight you loose your lubrication film which induces premature wear and can cause binding, and if things are too loose, you will get excessive vibration and poor surface finishes. On the flip side linear rails can come with a preload in the bearing already which keeps things nice and tight all the time. I just got done with my conversion and I'll never go back. In fact, I'm so tickled with them i got a set for my cnc lathe as well.
I suppose i should also note that I did not get cheapo chinesium rails either. I spent the money and got nice (used) NSK rails and bearings.
Did you document your conversion?
