Well, it's been almost a year. Time to resurrect this old thread with an update and a few more questions. I had hoped to do the forestry harvest last year, but timber prices were in the toilet, and the harvest is what is paying for the shop. This past spring, prices were better so I signed a contract. Unfortunately with Covid-19 uncertainties, they insisted on a 1 year contract, so I don't know when it will be exactly. And of course timber prices have continued to go up sharply, so probably could have gotten an even better price now than 3 months ago. Isn't that always the way of it? In any case, it looks like I will be able to move forward in the next 6-9 months.
I've done some re-working and found it is less expensive to do one shed 40x60 than it is to do a central shop with two lean-toos on the sides. So, current concept is either a 40x60 or 40x72 with the front 1/3 or so used for equipment storage and the back 2/3 for the shop, something like this:
So, now for a few more questions.
1) Having a hard time deciding if I want to enclose the area for ag storage (as shown), or just have that end open but covered and the exterior wall of the shop 2/3 of the way down the length of structure. Enclosed would be better because the equipment would be better protected, and if I ever want/need to expand the shop, I just move the equipment outside. The downside is trying to hook-up the implements to the bobcat inside the building is begging to damage the building at some point... If I do keep the implements inside, I can back the truck out the center, and that gives room to maneuver. Requires three doors though, and the doors have to be narrower. Thoughts?
2) Which do you think is better, steel frame building or a pole barn? If I go with steel frame, I have to get an engineered slab. If I go with pole barn, there are Poles every 10 or 12 feet along the long access. Both will span 40ft. Probably the steel frame is stronger... don't know. Any one have experience with both?
3) I have been looking at insulation options. One option is foam wood pannels. They are OSB on one side, foam on the other. Wood is 7/16 up to 5/8 thick, foam from an inch and a half up to 11 1/2 inches.
https://www.bestmaterials.com/SearchResult.aspx?KeyWords=insullam Seems like it would be easy to put up, and provide the interior surface all in one step. Thoughts on this?
As always, I appreciate all of you guys input.
