- Sep 8, 2019
- 4,392
So I see that nobody is using a .0001” DTI for this task. Two years ago, I had a Shars .0005” DTI, but I mistakenly turned on the PM-25MV which quickly (and violently) tore off the plunger on that DTI. This is why I can’t have nice things LOL. I replaced that .0005” DTI with the .0001” DTI that I was using yesterday. The .0001” is so fine that it is jerky at best. I have always wanted a quality .0005” DTI, specifically a Brown and Sharpe BesTest which are expensive; I hesitate to buy any used DI or DTI on eBay because I have done so a few times, only to end up with a sticky plunger.
Would you believe that I *forgot* the idea of using a 1-2-3 block for the task of tramming a head? The idea of raising and lowering the table immediately introduces the possibility of .0002” error, even with a DRO.
That NOGA centering indicator holder is much nicer than the super cheap unit that I have now.
I was also measuring against the table rather than the vise. I can see that the vise makes more sense, at least for work held in the vise.
As an experiment (and while I await my Edge Technology product), I will try again with the .0001” DTI using 1-2-3 blocks on the vise, but I anticipate jerkiness in the DTI, a less than rigid setup with the cheap centering indicator holder and maybe even a sticky plunger on the cheap DTI.
