- Nov 15, 2016
- 943
"carosine"? Sorry, I'm not following. Kerosene is a fractal distillate of oil one step up from No.2 Diesel. Years ago it was also known as No.1 Diesel. It is a hydrocarbon solvent commonly used for cleaning and it leaves a slightly oily residue. Immiscible in water. Diesel can be used for cleaning as well but is more of a lubricant than a solvent.
If you were using Kerosene,also known as Paraffin,you would need to use a detergent to remove it or a still lighter hydrocarbon solvent such as White Spirits or Naphtha. Blowing off with air to dry is all that is needed and as any small traces left would be 100% compatible with any mineral oil so there would be no problems. I think whoever had you rinse the parts with water didn't understand the process. I hope this is of use.
P.S. 'Lighting' Kerosene is a highly refined version and usually not tinted.
