Gear covers
Dave,
Don't you have the full cover? I asked earlier whether you had the L6-724.
Robert D.
OK. Then I understand how your wife must have gotten her chuckle. :)) If you decide to try to find a full cover, look for one for 101.07403. Same cover but much more likely to be listed that way.
Robert D.
Robert D.
I went through the belt train and tightened all the nuts. When I put the gear covers back on I noticed the hole for the number 10 screw in the rear of the cover was oversized. I held the right side cover as far to the right as possible when I tightened it. The left side cover also had an oversize hole and I held the cover to the left. When I flipped the switch and the lathe started there was no noise.
Dave.
Sounds like a good fix. No noise and no slung oil.
Robert D.
