Gear between carriage and rack on Hardinge TL
Hi Guys. Have gotten some good posts back - great info - during the restoration of the Hardinge TL (thanks Jim!), and it is going together very well ... hope to have first chips within next week, however one thing that is being hard to over come is the gear that runs between the carriage and the rack .... it has broken somewhere along the line and the previous owner put a 12 tooth little gear where the original 11 was. It works - turns things great ... a little bit of backlash but livable, but I think when I start threading, that extra tooth is going to throw off my feed rate, so I still need to figure out how to get that gear replaced, either from a salvage or from someone who can cut one. I did find out that there are a couple of other guys who are also facing this, so if anyone has any sources or thoughts I am sure we would all appreciate it who have the same problem. I will get some new pictures of it within next few days. the machine is 1944 and the experts I have been in contact with thus far are skeptical if we can find this out on a net anyplace (and I am sure we are all scouring every resource we can find!) This is not something that I have to do right now, but it is going to be there until I get it fixed, and as I said, I think it will cause me problems in threading (??) ....thanks in advance for any/all help/thoughts.
Doug W6PUG (I am also a ham radio operator and we have a houseful of pugs, so that is where that came from).
Guys, I have another issue that came up. When I transported it up here on a trailer, the potholes connected to potholes on I-5 did something that is kicking my butt.... all of the sudden, something is going on in the headstock and the autofeed shaft will not engage/turn. It was well strapped down on the trailer - did not budge ... autofeed was working fine before I left; got it up here and nada. It is almost like a pin vibrated out during the trip or something, but I am afraid to tear into headstock because I do not know if it has preload on it or anything - there is no manual or drawings or anything available on it that I have ever found .... I did check the half-nut on the crossfeed just to see if it was engaging and it is, but of course makes no difference if feed shaft isn't turning ... so does anyone know how the guts in the headstock work? I did go down today and picked up a flexible borescope so I can look up inside the headstock from the bottom - If I knew what to look for. Lathe is still usable by manual feed but I sure don't have a steady enough hand to get the finish I like ... could sure use some advice!
Thanks in advance - I appreciate any insight any of you have. I was going to contact Jim Swaggert but I bombed my other computer and lost email addresses >:eek:(
Thanks again - doug
Wish I could help, But not familiar with the TC lathe. Do you have any pictures?
A 3d printed plastic changegear will probably work fine, but a carriage feed gear would snap pretty quickly. Even if printed in the more solid ABS plastic which is harder to print on most hobby 3d printers.
I would buy and modify a gear and just be done with it. This gear determines accuracy (if you have a longitudinal feed dial) of your lathe, make sure it's made with accuracy. The wrong gear would also probably cause a lumpy Z axis feed.
It won't hurt threading, you use the leadscrew and halfnuts to thread.
I do not have any recent ones but I can sure take some this weekend and post. It is a Hardinge TL lathe made at end of WW!! / problem is that at that time, Hardinge was pushing them out the door (something like 2-3 different models) to the point that they were being serial numbered by going out the door, not by model. To best of my knowledge there was no manual and no schematic drawing. There was a 10 page brochure that someone found and posted which identified the knobs and levers but that was about it. One thing I learned from this forum was that it was very similar to a "T-10", but frankly, the only Hardinge I have ever seen that was well documented is the various generations of the HLV .... so I am kind of at a loss ... my best hope is that someone else has one, or is a machinist who learned from a machine of that era, or something like that .... so I would be very grateful for any info I can get. I can take photos ... would it help for me to take a short video of operating the levers and such and show what is 'not' happening?
Thanks for inquiring and I will get pix posted ... if any of you have any ideas, I would really appreciate it to bring this thing back to proper life .... it is my favorite tool, and this is really bugging me. Thanks again - doug
Anything would be helpful. Since it was working prior to transporting.
I actually already have this one - this is the one I mentioned that had all of the knobs and levers identified - in fact, I think someone on this forum emailed it to me some time ago, and another one about threading with the TL - but thank you for looking too ... this weekend was first 'normal' weekend wife and I have had at home - she has been commuting weekends for past 10 months and finally got situated up here so we did house stuff and I need to get those pix taken ...
But thank you again for looking!!! I am hoping that a pin fell out or something during the transit and I just need to find and replace it, but it is definitely a puzzle for me ... Take care and hope your Halloween is a celebration and not too nuts! Cheers! doug
Hi guys ... work has been nuts and believe it or not even after a year I am still opening boxes and putting stuff away. I will certainly keep the 3D printer idea in mind ... I found all of the docs you guys suggested so far but of course none of them are exploded drawings or maintenance manual or anything. For some reason I thought that since the HLV came out in about the same time that my TL was turning into a dinosaur, they might have carried that part (what goes on behind the curtain - uh, I mean under the apron) design forward but so far no joy. I have kinda gotten it down to the auto feed engage lever problem and I think there is a l ittle clutch under that, but it is brutal to get that off because the manual feel handwheel is in the way, so Doug thinks to himself, "Meself, remove the handwheel .... " easier said than done. DSC_0350.JPG DSC_0351.JPG
So, thanks to the patience of you guys, I have not pushed it into the back corner of the shop in abandonment. I know there is an answer ... I am just not smart enough to make it work (yet) but one of you guys will have seen it and make it make sense to me eventually ... I just appreciate everybody's ideas and patience. I think this is the last issue with the thing. It was somewhat abused before I got it - see the scratch marks in the bed way? Some genius thought that was going to improve oil under the crossfeed movement .... so it has a better home, but still needs help :eek:) Thanks Guys! I truly am grateful for your input. ddj at PugWerks
OBTW - do you guys use syringes to lubricate those ball spring gizmos you see in the picture? Was there some tool that was better for that?
please see attached - is this what you used to use to lubricate the crossfeed and way on the lathe? Mine has these little ball and spring things and I am using a syringe to supply oil .... kind of a pain ... and I wondered what was really used "back in the day" ....
