- Jun 28, 2021
- 146
I have never done MIG welding so I'm not the one to ask. I have used MIG wire for 4130 because you could buy a spool of small diameter weld wire for doing delicate parts.
I hope not! I definitely see the puddle when TIG welding aluminum. I find it easy to see actually. You should have a good puddle and each dab of the filler causes that spot to solidify as soon as you move past it. That's how you get the nearly mirror finish beads...adding the filler freezes the puddle. If it's a frosty finish it had too much time to cool and glazes over.Regarding not seeing the puddle in aluminum while gas welding, isn’t this the same as not seeing the puddle in aluminum while TIG welding?
By the way, this is why I prefer TIG welding on steel rather than on aluminum because of not being able to see the keyhole. I only choose aluminum when steel will not suit the application.
Honestly, I find steel to be very user friendly, but I have yet to warm up to aluminum as a material for welding.
We are lucky to have TIG as an option for welding aluminum, as the aluminum stick welding electrodes are a challenge (although once the base material is warmed up they will function).
I don't know about the magnetic issue, but most chrome moly aircraft frames are definitely TIG welded now. Some companies are using MIG, but they are using expensive machines with pulse functions, pre-heating the tubing and then proper annealing afterwards...along with having experienced welders who know what they're doing.Question about welding aircraft tubing? I was once told they were gas welded so the frame did not get magnetized and interfere with the compass. Is this a myth? Sounds like arc welding is now used?
LOL - yes. It was quite humbling!Thanks Gaffer! After watching that video, I will likely give up welding....
