- Jun 7, 2013
- 10,483
In a way, I can appreciate that the Cincinnati dividing head has high number plates with some prime numbers, such as 53 having been previously discussed; this lessens the necessity for differential indexing that is necessary with the B&S type of dividing head; it requires concentration and care to do normal indexing, but with differential indexing, having the dividing plate revolve at the same time that the worm crank is being turned makes it all the worse and increases the chance of mistakes being made; having said that, The B&S is the one that I own and use, and have needed to differential index many times, like for making prime number change gears, such as the 127 tooth for metric transposing.
The Cincinnati dividing head will divide 33 with the standard dividing plate, which is double sided (only one plate is supplied), and a high number plate, (optional at extra cost) will divide 127, both not requiring differential indexing.
I have a Cincinnati end gear train and change gears that are surplus to my needs if anyone has an interest in spiral cutting capability; it came off a #2 universal made in the late 1930s.
