In case anyone wandering into this thread is looking for an alternative to the current residential door openers, I can wholeheartedly recommend Zap commercial openers.
They use DC motors, and using current draw to identify limits and obstructions they don't rely on programming or external sensors to set limits or to be safe. They do use beam-breaker safeties because of code, but won't kill anyone even if they close on a person (they will self-limit before serious injury). They are belt-driven on the jackshaft, and the emergency clutch simply releases the belt tension so the door can be operated manually. But because they are belt-driven, they are also very quiet--generally far quieter than the rollers on the door itself. They include outputs for lights and inputs for external radio receivers (I installed Liftmaster radio receivers on mine for remote operation).
They are somewhat more expensive than residential openers, but not really by enough to make them out of reach. I used the medium-duty openers in my shop but even the light-duty openers should be enough for the doors most of us will have.
Rick "installed four of them with all the accessories for $2500" Denney
Zap
<p>Zap Controls garage door openers and accessories are a range of products with uses in both the commercial, residential and industrial sectors. North Shore Commercial Door carries their jackshaft openers, controllers, remotes and loop detectors at great prices. Their advanced products can be...
www.northshorecommercialdoor.com
