So, taking the parallels aren't necessarily parallel along their wide sides in to account, I just did it with 1-2-3 blocks to check it that way.As I look at the three photos, the low spot is in the middle @ -.0027", At the far end, you are @ +.0009 and at the near end, you are a+.0028".
A parallel is not necessarily a flat surface on its wide face nor is it necessarily uniform thickness between the wide faces. It is meant to be uniform in thickness between the two narrow faces with a face surface on each.
